erasedhammer
- 59
- 28
- Maryland
My tachometer (style that mounts next to the w/s wiper motor) was working after my 200amp upgrade and after my A2 engine harness upgrade, but now is not working after my A2 body harness upgrade.
A/c ring terminal is hooked up to the tachometer a/c tap. The other cable is plugged into the original harness A/c wire.
Power wire for the tach is plugged into the 24v cable for the fuel gauge. The other wire on the tach harness is plugged into the fuel gauge itself.
Tach grounding wire is secured down onto the fuel gauge grounding stud with the fuel gauge ground wire.
There is 24v power on the end of the original fuel gauge power wire, and the fuel gauge works.
I check voltage accross pins A and C as well as A and D on the tachometer plug. When the truck is running I get 12v and 5v for A & C, A &D.
All the other pins show no voltage when compared with pin A.
It's not the tach gauge itself cause I plugged in another one I had laying around and it didn't work either.
It used to work... What am I missing?
Only things that have changed is the body harness and the three wires that plug into the dash. Rest is constant
