TechnoWeenie
1,669
Nova Laboratories, WA
Has anybody mounted rear facing work lights to the cab on a m1009? Looking for pictures and ideas?
Pointers on sealing the mounting holes other than silicon and or orings.
If you use a high grade marine sealant, the bond/'waterproofness' will last longer than the truck.... Don't be afraid to drill, just be aware that it's a double walled roof... long bolts are your friend..
cucvrus
10,132
Jonestown Pennsylvania
I would recommend using self tapping screws in the fiberglass top. I drill a 1/8" hole and used self tapping screws to mount high mount stop lights and an LED light bar on the rear roof area of an M1009. I also have a recessed LED license light in the M1009. I ran all the wires up from the bottom in the rear corner post. Fished the wire thru with mig wire. A bit tricky but doable. Even after 24 long necks. I remember it well. That rear corner area has more steel in it then one might realize. I have pictures some where if needed. The high mount brake light requires the wire to come right off the brake pedal wire. Or it will blink when the turn signals are on. It does flash when the 4 ways are on. Good Luck. Post some pictures.
3jumpjeep
Linsdale, TN
Long bolts and wide washers to spread the load. Marine sealant sounds good. I was going to mention RV sealants.
Sent from my SCH-I545 using Tapatalk
peglegwillie
Knoxville Tennseess
Fuel filter !!!
In tank pump removed when tank cleaned out. Replaced with in line pump on frame rail. Apparently it got hot and shut down.
Up date'. Fuel filter on frame rail after pump clogged,, had to by pass to get fuel to engine worked fuel filter on firewall should work going to replace bad filter. Finished trip picked up rolling ton frame 60' front. 14b rear plus all connections!!!
camok5
France
[QUOTE = CUCVLOVER; 2009045] La partie arrière du haut est la fibre de verre correcte? Donc ça va durer parce que nulle part où souder un support ou utiliser un aimant. Vous feriez probablement mieux de monter un peu sur le pare-chocs, puis avoir un jeu supplémentaire sur certains pôles, vous pouvez vous brancher là-bas quelque part que vous pouvez accrocher le pare-chocs. Ou si vous avez utilisé un support d'antenne de chaque côté à l'arrière qui pourrait fonctionner. [/ QUOTE]
like this bumper with working lamp ....
CUCVLOVER
I was thinking something exactly like that. Looks good man
camok5
France
I think the rear axle on the right side may be part of the problem he is trying to relay. Not a bad job on the caged bumper lights. Is a Red rear bumper required in France?
No need to be red it was a primer, Yes original axles C clips broke then the half shaft is output
Today
cucvrus
10,132
Yes original axles C clips broke.
C clip still looks good to me. The center carrier/clutch section not so good. I have a complete new center carrier for the M1009. I have had it for years. Just the carrier. No ring or pinion. I also have a few complete rear axles in crates. France. Not sure but the shipping would be a killer for sure. I se you use your M1009 hard like I do also. What was the final fatal blow to the 10 bolt? Good Luck.
camok5
France
It is equipped with the 14Bff and Dana60 with spartan, It has a lot of modification on it
swiss
763
Oakwood, Ga
Need some opinions and we have plenty on site. Trying to figure out right height for. 101 top
This is the original height.
Vote for 1 or 2
1. Leave alone and only put on when needed
2. Cut down 6" and have more streamlined with cab? I may take out some more of the uprights also
swiss
763
Oakwood, Ga
Pics
I have a new camo top and this is not the cover I am going to use but it is an m101 for sizing
I also have to add 2 more bows and running to Home Depot for metal saw
