storing my humvee for 3 months
erasedhammer
61
Maryland
I will be storing my humvee for 3 months soon and there will be no one to drive it or operate it for that time.
I wanted to see what everyone thinks about what I should do prior to parking the vehicle and leaving.
So far I got: Disconnect batteries, chock the wheels, park it in a garage, fresh oil, top the tank off... what else?
AAVP7
263
Dortmund, Germany
Three months is a comparatively short time. Topping off the tank is done for vehicles with steel tanks to prevent rust, but with the plastic tank that´s not really a concern.
What I would definitely do is use a battery tender. Lead-acid batteries have a pretty high self-discharge rate, and can be dead after three months even when disconnected.
diesel dave
north central pa
Topping off the tank has as much to do with keeping moisture (condensation)out of the entire fuel system as it does tank corrosion. Top off the tank and disconnect the batteries. That's what I do for all my "toys" every winter. Never had a problem.
Sintorion
14
Fla
Mine sat on the lot for at least 3 months completely unattended in the open with no top from the time I saw it until I picked it up. They charged the batteries the day before and it fired right up when I got there. I think you will be fine.
dk8019
55
Lovettsville, VA
Mine often sits 3 months over the winter in a protected barn. I throw the batteries on the solar system and she's ready to go the next spring.
teteacher101
WI
When I picked up my Humvee the guy on the base told me he thought mine sat for almost 5 years. He had it fired up and going before I got there an he said it cranked for a few seconds an fired right up with only a slight injector knock-so I don't think 3 months will be so bad!
I would also do the following:
-Put a fuel stabilizer in it and run it for a few miles before you store it.
-Take a section of wire screen an wire tie it over your exhaust pipe and your air intake.
-Sometimes for longer storage of vehicles people will put the vehicle on blocks to get the weight off the tires-I dont think I would for only 3 months.
-Spray the belts, tires, hoses, etc., with your favorite brand of "Armor All" type of product.
Havok
Boston/MA
I would definitely add fuel stabil it will help with the condensation more than topping off. In my other toys I add moisture absorbers for the interior but not really a concern here.
Action
1,561
East Tennessee
I wouldnt armorall your belts!
juanprado
3,074
Metairie/La (N'awlins)
I would not recommend to spray the hoses either. Car Dealerships and used car lots sometimes spray this shiny clear stuff under the hood to dress them up. This stuff makes the hoses go bad quickly along with belts. Used to see all kinds of bad hoses and belts in my parts selling days from these "detailed" cars/trucks......
teteacher101
WI
My apologies to everybody; when I put "Armor All" in parenthesis I meant it as a blanket statement for treatment of rubber parts/components since there are so many different products that are made specifically for certain applications to aid in UV protection, dry rot, etc. I meant to leave the specific product choice up to whomever feels like it is needed or not needed-which is solely based on one's personal experience and opinion. Sorry for the confusion on my original response.
