- 16,766
- 24,082
- Burgkunstadt, Germany
The short answer is no. Any kind of battery that will fit in the set, and has enough CCA will do. Having said that, some batteries will not allow you to use the Army battery hold downs, or you have to modify them to work. Or make something that will work. OR find a battery that not only fits, but will let you use the army hold downs. If your AN/MJQ-35 Power Plant is going to become a fixed power source, holdowns are not a real big issue for some folks. I would have them, but when you are not driving down a rutted road, well you can get by without them, at your risk. If you intend to drive your trailer around, I would say you need them. What kind of batteries? Well, there are several threads where this subject has been discussed till the cows come home. General consensus is that everyone has there own favorite battery. Read and get smart.Will these gen sets only start with optima yellow tops? I replaced all 4 batteries. I gen runs fine the second won't start at the switch. It will prime the pump but when turned to start it makes no sound. Totally dead I had a diagnostics run on it and the gen shop tells me it's only getting 18 volts. Starter and relays all good. Don't know if it's a combo bad switch and electrical issue.View attachment 679550
In addition to the full set of MEP-802A gen set manuals, you need:
TM 9-2320-213-14&P for the trailer portion.
TM 9-6115-659-13&P for the Power Plant.
These manuals are posted in the TM Forum.
Please take a picture in the control panel, so we can see if you have a MK1, MK2 or MK3 S-1 start switch.
