ridenby
- 18
- 18
- Frankfort,Ky
Changed door locks, mounted two KC HID lights,two 6inch LED light bars on front,two 2inch LED cubes on rear. I can see!!
Yes, there are three on each fork... but you never know what you will find wrong till you open it up. I pulled one apart today that came out of a 60,000 mile CUCV that never saw the road after it was auctioned. It was missing the brass syncro (for lack of a better description) had one really worn fork and no magnet inside, along with couple other ground up parts.Doesthe NP208 have the plastic spacers on the forks. Mine does and now Ihave to put them in because some one did not do it , it jumps out ofgear and then your in neutral.
Hey, Joshua, sure hope everything is fine with you all!I replaced the front leaf spring bushings with Energy Suspension Bushings (3.2105).
Old bushings
View attachment 679555View attachment 679554
Yes, all is well. Same good wishes for ya'll.Hey, Joshua, sure hope everything is fine with you all!
Have you maybe got a pic of the new bushings?
That's good clean work. Your rig looks great.In the past couple of months I have installed a light bar, cab clearance lights, pulled the motor to reseal and do freeze plugs, painted the engine a tan color (wanted to do the detroit green but funds are tight) and compartment. As you can see in the pictures, hopefully they attached haha
Post part numbers also if you would.Yes, all is well. Same good wishes for ya'll.
A picture of the new bushing would make sense wouldn't it? I must say I didn't take one, but will when I get home and will edit this post tomorrow.
Tomorrow is today.
Two posts above the one you quoted sir, part number and hyperlink to their online store queued up for the parts they offer for our K5.Post part numbers also if you would.
It will help others wanting to do the same thing.
All 6 looked pretty sad.
Also rebuilt and painted a couple of spare alternators. The rebuild kits were from member Tow4.
View attachment 679560 View attachment 679561
I totally missed that!Two posts above the one you quoted sir, part number and hyperlink to their online store queued up for the parts they offer for our K5.
I'll quote myself...
That trailer combo is very desirable and a tough find here in the US, let alone where you are.Didn't do anything, just drove around, saw an old friend, chatted and asked him to be on the lookout for 2 new 33x12.5x16.5 tires.
Still contemplating if it was a good idea to sell the trailer with shelter combo..
