Bravojmc
- 5
- 0
- Palisade, Colorado
This is the CB I'm running in my rig.I found a couple and tried them out. Using one gets hot when the radio is on even with no sound - just back lights. Using two get warm but heat up if the squelch breaks. They get verrrry hot trying to transmit. There is also a small voltage drop leaving less than 11.5 volts while trying to transmit. Also it takes over 14 volts before they can get to 12 volt out. They work good for small loads...
I will try to round up a few more and see how many it takes to make a 12v CB run on 24v reliably - next time I get board...
running it on 24v
