FullSpecial
- 105
- 43
- Denton TX
Nice software.
I noticed when I went to to cut holes in the bumper for lights.. rather..a member here helped me out when I was on a road trip...Anyone else notice that the cutout in the bumper for the winch is offset to one side? I never noticed it until last when I was pulling measurements.
Sent from my SM-G900V using Tapatalk
I plan to switch all of mine over to 1/4 turn ball valves with long (ish) handles....and locks...About once a month I go around with a bottle of soapy water and check the truck for air leaks. I found a couple this time around.
1. The #2 tank drain cock (yes, I said it) had a slight leak no matter how tightly it was closed.
I replaced all 4 with a new style I ran across a couple months back. These look to have been used on MRAPs and FMTVs according to Parttarget. NSN 4820-01-363-2117
2. The valve on the the transfer case, to auto engage the front axle in low, was leaking slightly around the shaft.
I disabled the valve a couple years ago. I'll eliminate it, and all the extra lines, completely after I get a couple of fittings.
I've never really checked inside the cab but I did this time since the T-case valve was leaking. The T-case valve is the same one used on the parking brake handle. Sure enough, the parking brake valve had a slight leak around the shaft too.
While I had it all apart I decided to replace everything down there with new parts. I replaced the handle, valve, switch, bracket and cable.
you just ruined the front of the truck for all of our OCD members! They will be cutting and grinding to make it even.Anyone else notice that the cutout in the bumper for the winch is offset to one side? I never noticed it until last when I was pulling measurements.
Sorry. Offer to buy it back for 10% of what you sold it for then.Swamp Donkey, anyone who says your truck isn't loved, is a fool. Kudos to you for keeping up with it.
I visited one one of my old trucks yesterday that I fixed up painted and sold, and it was a mess. All the windows were open, master switch on, batteries dead, had been run into a tree, front turn signal light and quarter panel bent. It made me sad, because this truck was the most solid truck I have ever owned, including the one I currently have. I see that it will be a junk pile in a year.![]()
That is just stupidity at its finest. Pay good money for a truck, just to tear it up.I visited one one of my old trucks yesterday that I fixed up painted and sold, and it was a mess. All the windows were open, master switch on, batteries dead, had been run into a tree, front turn signal light and quarter panel bent. It made me sad, because this truck was the most solid truck I have ever owned, including the one I currently have. I see that it will be a junk pile in a year.![]()
I lucked out and both my 5 tons are excellent trucks.I completely understand! I really don't need one of my Goats, BUT , every one who offers to buy it wants to pay $5.00 , because every one knows they still come in crates for $5.00 each. Then they all go on to tell me how there going to take it in the nearby lake, run over trees and generally destroy it to see "WHAT THAT BABY WILL DO"! Suspect I will never part with any of them.
Yup, it's his truck, not mine. I'd like to help him maintain it though. You can't make someone care.That is just stupidity at its finest. Pay good money for a truck, just to tear it up.
The supply of good, solid trucks has slowed to a trickle.
They won't last forever.
