How is accessory drive unit of rear of transmission pto hooked up to cab controls in?
sawmill71
NewYork
Hello,
I am adding an accessory drive pto to my existing transmission pto for front winch and was wondering what linkage or control cables I need to hook it up with? If anyone has information or parts or both it would be a great help.
gimpyrobb
dumpsterlandingfromorbit!
27,786
757
Cincy Ohio
Well since this is in the deuce section, I'm going with m35a2.
I'd use an air cyl or vernier cable to operate the pto. If memory serves, stock config is mechanical.
gringeltaube
Staff Member
2,570
Montevideo/Uruguay
Hello, I ....... was wondering what linkage or control cables I need to hook it up with? ..............
See this thread, posts #22 and 26.
The other alternative is what Gimpy mentioned: yes, a small air cylinder works very well! Simply connect both shafts via a small Ø3/8" pushrod and two pieces of HP-hydraulic hoses clamped to the ends.
Below is a pic of one of my applications... and this other picture, which barely shows said linkage, hidden in the background.
