Another Ahab
4,556
Alexandria, VA
Can't decide what to do as far as a paint scheme. Stick with an MV based job, or civilianize it since it'll be my permanent residence. Maybe a multi-level metal flake scheme like a 60's drag car.
Some of those WWI camouflage schemes used by Germany on their aircraft were pretty funky.
Of course, those schemes were:
- WWI era.
- German
- And aircraft specific.
But. You know. Other than that. Pretty funky!
someoldmoose
Lancaster, PA
Ahab, that just might be the answer. [thumbzup] I too am WW 1 vintage (or at least it feels that way), of German heritage, Virgo (so VERY specific), and pretty funky (especially after a fire call but better after a shower). Maybe I will become Moose Fred van Rick tofu.
The Maroon Bar man.
therooster2001
44
Colorado
Found two things that need attention. Not a dripping leak, but I think when it articulated it threw some oil around. Both rear axels. Time to read up..
Coffey1
497
Gray Court SC
Rear pinion seal super easy.
Pull cotter key remove nut pull flange off by hand remove seal install new seal. Fronts are a little different.
Tinstar
1,776
Edmond, Oklahoma
It is very easy.
I have read on SS that there is a difference between military spec seals and civilian seals.
The military one seems to do the job and the civilian one leaks right away.
I used the military one and it was fine.
No experience with the other
Ford Mechanic
Edenton, NC
It is very easy.
Really? I was just fixing to order some civy replacement seals.
Sent from my SM-G900V using Tapatalk
tobyS
833
IN
Cut the sideboards from telephone poles today and fitted them. One of the four got about 1 3/4" and the rest are 1 1/2". I'm going to see if a shop nearby will plane the one down just a tad. They weigh a bit more than 2x 12 from the lumber mart.
Sunburn, sweat and saw dust is a hot combination right now!:burn:
Black, tan or green?
simp5782
Feo, Fuerte y Formal
9,384
Mason, TN
Ive never had any of the civilian ones leak and i use the ones from napa or truckpro. National oil seals are good quality.
Sent from my SM-G935P using Tapatalk
Tinstar
1,776
Edmond, Oklahoma
I'm not doubting that at all.
Just relaying what Ive read in a few old SS threads.
The military surplus seals must be made of gold considering how much the eBay, etc. vendors ask for them.
Jbulach
2,194
Sunman Indiana
Cut the sideboards from telephone poles today....
....Sunburn, sweat and saw dust is a hot combination right now!:burn:
Oh no, I hope you didn't get Creosote burned. I've been burned several times and it makes a sunburn seem like fun.
The side boards look awesome. I'd go green if you can match or just leave them as is, look cool to me! Just my $.02
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Leave them as is, looks sharp!
