- 3,871
- 497
- 83
- Gray Court SC
Ya'll don't forget to check the sticky and if your info has not yet been reported consider sending it to Simp5782 to help everyone out.simp5782 said:.... Added 3/20/17.
Glad you looked at his spread sheet. He must have misstakinly read the numbers wrong or something when I sent it to him..... or I miss understood myself what he said, and you already sent him this info in a PM? It is his reply to me in the quote posted above.I have no clue what your seeing, that was the first place I looked.
He does have the N50013D number there. Which is no longer active. The new compressor number is Active El16280 !
You can buy them brand new at napa! Expensive $ 1700.00.
You can also buy the parts to rebuild piston, gasket, valves also at napa I have part numbers for those as well.
Could you point me to that parts spreadsheet? I haven’t found it yet...Sent this to be put into the easy use parts spreadsheet that can be accessed thru sticky on top of this page.
you can send it thru my Facebook Pay.... I'll expect it tomorrowThanks a million!
