- 1,450
- 119
- 63
- Gray, GA
Gotcha. Acetone/ATF is a wonderful mixture. You need to try it.
You got some more pictures of that front bumper and winch setup you have SD?Just add something useful to the front like a winch, heavy bumper or storage boxes...or all of the above. Replace shocks with some gas units and keep the shackle pins well greased. Make those springs work a little and you'll find comfort.
My front axle scales 12,700# as it sits in the picture. It's like driving a cloud. Even a couple hundred pounds will make a bigger difference than you think. I didn't add all that at once.
They're scattered all over the place. See the thread below:You got some more pictures of that front bumper and winch setup you have SD?
Here is a picture of the setup Profo did.//cloud.tapatalk.com/s/593ce607e6702/IMG_9131.jpg?I would like to chime in I put air bags on top of my leaf springs and I removed one spring so far and there is no noticeable difference my plan is to remove two more and stop at that if it doesn't improve I am working with a spring company to make a progressively load handling spring similar to a Lmtv spring the problem with my truck it is a camper and I can't haul a heavier load other than a trailer which is on the rear so it should be able tweak easily, I also found out that since I have a 8.3 it's a lil lighter than the 250 engine but I believe they both use the same spring, so with this said the springs are just to heavy for normal use around house, I put a camera under truck focused on spring and unless you jump a railroad track they DO NOT FLEX more that a 1/4 inch on normal LOUISANA roads!
A cracked or broken spring is a red tag item and the truck is out of service until the spring is replacedYes one is broke and starting to walk out. One is just cracked. This is the second set of springs on two different bogeys.
I will post some pics tonight in my 60k mile report.
Sent from my SM-G935P using Tapatalk
Well by all means come replace my springs for me.A cracked or broken spring is a red tag item and the truck is out of service until the spring is replaced
That broken lower spring will not come out. It will only walk so far before the bend and force of its sister spring stops it. It will hit the A1 spring brake can holders. But no airlines.I you people want to endanger the lives of the other people on the road as well as yours then this hobby is doomed.
A broken leaf Spring can pop out and go through someone else's windshield killing a person in the car, it can also shred tires, air lines or worse.
You can barely get the dang thing out with the spring pack dissassembled.
I have seen a lot of crazy stuff over the years.
