scootertrs
- 7
- 28
- miami/florida
Well, here is my sequence... MEP-805B Generator would not start and panel showed a fault. Arrow was unresponsive in display. after reading several posts (thank you) I developed enough intestinal fortitude to open "pandora's box". After opening and being quite pleased at finding no water within, I continued to investigate and saw one pink wire going to a 2 pin plug had broken off. I repaired that, continued the inspection, seeing nothing else out of place, reassembled it after adding rtv sealant to the cover and de-oxit to the plugs. reinstalled it and now, the arrow moved with the controls.
Attempted to start, no-go... read the manual, held the "fault-clear switch for 2 sec. checked panel and all showed well, including accurate fuel level. genset fired up and ran like a top, generating power without issue, but now my fuel gauge showed no fuel. Momentary jumping of fuel gauge terminals gave me a reading. Any ideas?
What could make the gauge read correct when genset is off and not at all when genset is running?
Thanks for the help.
