eatont9999
- 0
- 0
- DFW, Texas
Right. I don't want to find out I have a leak after I put in expensive fluids. I have not seen it anywhere but do these engines have a problem with cavitation? If so, I will use antifreeze pre-charged with SCA.Originally Posted by csheath
If that is just the auction fee your cost will go up from there. GL charges a 12% buyer's premium plus sales tax for the state/county the units are sold in.
These skids don't slide all that easy on metal. I had mine in the back of my pickup and winched it out onto a trailer for starters. After I got it sorted out I drug it off the trailer with my tractor. When I was winching it out of the truck I had to put tension on the cable then work the unit side to side with a crowbar to get it to move then I would retention the cable some more.
Look over any maintenance notes they may have and make sureyou add oil and at least water before attempting to start them. Be ready to shut it back down and replace the return fuel hoses. If they hadn't been done recently they will most likely leak. I used 1/8"/3.2mm Gates fuel hose for the small return lines. I bought it at Oreily auto parts. The short hoses have the crimped metal clamping that can be cut away and replaced with 1/4" fuel hose.
You will need some way to load the units for testing and sorting other than your house. One quick and easy solution is to find a cheap or free electric range. They take up considerable space but are pretty much a ready to use load bank. I saw one local to me in the free section on Craigslist the other day.
Use the cheapest oil you can find, and do not use antifreeze. Just water. It's a waste to do it any other way. Then run it a few hours under load if you can. Change oil, filters and put in antifreeze.
We aim to please!!
As for well nuts, I may want to replace those simply out of good measure. I really don't want to walk into the shop one day and see a few dozen gallons of fuel on the floor.
I have several interested parties for the extra generators. It may turn out to be a profitable venture. I specialize in Diesel engines, so getting those running will be the easy part. The electrical stuff not so much.
