M1088 Cab went up, now won't come all the way down
Reworked LMTV
1,174
TN
:roll: Ok so my cab went up, and now it won't go all the way down. Bad check valve or stuck valve?
Coffey1
497
Gray Court SC
Pull hoses off of cylinder just make sure your way under truck.
If still won't come down the cylinder is locked.
GreyEnvy
North Mississippi
Mine started hanging up last week. The cab is hitting the cab support bar. I used a long pry-bar to nudge the support bar backwards out of the way.
I wonder if I have an airbag failure? I don't think it was this floppy before.
serpico760
1,750
San Diego, CA
My support bar that holds the back of the cab flops towards the engine too close and goes over the ramp the seats it into place I'm not sure if something is out of adjustment or if they're supposed to be a strap that contains it but anyway I've used bungee cords wrapping around the tire rack and going to that
Sent from my S62 Pro using Tapatalk
Lostchain
587
Portland, OR
This sounds like the problem I had with mine, it was related to lowering the cab with the cab air leveling system engaged. I always raise and lower the cab with the air ride bags deflated and I haven't had the problem again.
Ronmar
7,474
Port angeles wa
There are internal shocks in the air bags that should keep things mostly inline either inflated or deflated, and limit overall travel. Mine works fine inflated or deflated, so I would say you have a deeper problem, or they are not installed correctly. The shock is attached into its base flange by a single bolt and bushing. If that is loose it will allow the whole assembly to tilt. The top of the shock is attached by a cross pin. If that upper bushing/pin is trash, it will pivot at the top. If you raise the cab and move the arch, you should be able to see where it is pivoting(top or bottom of shock) if you get up there and pull up and down onthe arch you should feel only smooth shock response, and no free-play/slop/clunking…
