Flatlander
- 3
- 18
- Lubbock, Texas
So I won a truck and am awaiting my EUC to clear. I spoke with the site rep and he told me that he cranks the truck, fuel gets to the injection pump, but goes no further. His opinion is that there is a shear pin on the gear that drives the pin that needs replacement. Is this an issue any of you have seen? If it shears, is the IP likely to need replacement?
He said there is a cover that can be removed to visualize the pin. I'm thinking I can do that if needed, and probably can replace the pump if needed. Haven't done it before, but after reading the TM it dosn't look too difficult. I'm a little foggy on the timing procedure, is that difficult?
