Brutacus
207
Marion, AR.
Today, I replaced my batteries with 2 new 8D-6 batteries, made a triple ought gauge cable to connect the two, and I've installed one of those Keyed ignition switches. I also found 2 loose/worn out wire connectors going to the ignition switch. Those loose wires are now on my "next to do list".
Hey has any one every made a battery holder for any 8D's? This is also on my "next to do list".
tobyS
833
IN
I used the boards from under to fill in the sides and between them. I cut some 1/2" stock for under them so the hold down tabs didn't poke the bottom. Then used a couple of boards on top so the seat bottom can't get down into the terminals...careful it's close if they are the 1400 cca. On one, I had to put rubber over the terminals and a sheet of plastic...okay old innertube and a opened up 2 liter. I took a Hawker with nearly melted off terminal out of that one from the seat bottom getting into the terminal.
Coffey1
497
Gray Court SC
Give him a break guys he's new.
I was teaching him how to post.
He has a 939 dump truck which I am sure he will show us.
Elijah95
Certified Rookie
1,239
1,185
Georgia
Ooh I'm excited to see, I'm contemplating setting my cargo bed up to dump
1974 AM General M109A3 w/Deuce Bed, White LDT, Whistler C, and soft top
Another Ahab
4,536
Alexandria, VA
Buffalobwana
177
Frisco Texas
Today I finally got around to it. I ©16'd my truck. That's right I copyrighted it. Please feel free to use the phrase and just PayPal me the royalties. Working on getting Wikipedia to update the term.
©16'd - (six-teen-ed) - to install giant 16.00 x 20 tires on ones vehicle.
Anyway, here's the pix. HEMTT rims up front. 5 ton combat rims on the back. Still trying to figure out the correct air pressure to keep from harming the tires and make it a reasonably comfortable ride while empty.
simp5782
Feo, Fuerte y Formal
9,366
Mason, TN
Went to a Push/Pull type parking brake valve on the dash. Easy mod. 15ft of 1/2" air line is needed and KN20021 parking brake valve. Pretty simple just run a supply line from the double check valve behind the fuel tank to the parking valve. Then run your delivery valve to the line coming off the front hose off the parking brake under the cab. It actually goes to a check valve in the drivers step. This is a great mod for those worried about their kids knocking the brakes off on the truck. About a $75 mod.
https://www.youtube.com/watch?v=ELcWO5Q2A1w&t=24s
Mos68x
36
Seligman,AZ
Don't blame him I told him to just say test.
It was a tiring day all I could think of at that moment.
I wasnt at all all worried about it, now the admins are a completely different story lol
View attachment 686972View attachment 686973View attachment 686974View attachment 686975
Buff, looks sexy
Buffalobwana
177
Frisco Texas
Mos, thanks! But, I don't know if I want to hear you say "buff" and sexy in the same sentence when talking about me! But hey, I'll take the compliments wherever they come from. They are getting harder to come by.
For a size comparison, check this picture out. Puts it in perspective. The guy isn't very tall, ironically, he had his son on FaceTime, a marine serving in the Middle East. God bless him and his family. Don't know either of them, but, I did take time to talk to the boy. Anyway, check out the size diff.
Now, this is interesting. My truck is more gutless at low rpm, low range than any other 5 ton I have driven. I thought adding 16's Would possibly be a mistake because of the increased size and difficulty turning the wheel to get up to speed.
Not only was it not a problem, it helped the performance. I have plenty of video that is with a stopwatch of me going 0 to 10, 20, 30, 40 and 50 with 14.00's. I will do the same with 16.00's as soon as I figure out what 10,20,30 etc actually is on my speedo, since it changed.
I can still cruise at 65 (gps verified) get to 70.3 on a downhill (I don't think I could do that before). So speed isn't negatively effected.
More on all this later.
Another Ahab
4,536
Alexandria, VA
$75 is pain, but it's not a big pain.
