M929 A2 over heating problem
Suprman
685
Stratford/Connecticut
FullSizeRender.jpg 4 1/4 thick. 24 volt fans. 16 by 23.5 inches. Running at 28 volts in the pic. Moves so much air it's hovering in the pic. Weighs around 15lbs. Hundred bucks plus shipping.
T2C
Arizona
View attachment 688810 4 1/4 thick. 24 volt fans. 16 by 23.5 inches. Running at 28 volts in the pic. Moves so much air it's hovering in the pic. Weighs around 15lbs. Hundred bucks plus shipping.
I'll check on Monday to make sure it fits, and that we're allowed to spend the money. Do i need to wire directly to the battery bank, or have you found a spare harness to attach to in the past?
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
The overheat light should have been disabled on all trucks per a MWO. It is generally faulty and unreliable. You have to realize all the worst evils on heat with these motors. Step one, get rid of your heat exchanger. You have an air to air transmission cooler in the grille. Just run it alone. Get rid of some engine heat this way. If you are having lots of overheating issues simply get a male JIC # 6 and make it a #6 on the opposite end and hook the fan clutch air lines together and make that thing come on all the time. It will also give you full blast on the clutch. Or go to a Horton style fan clutch control so you can turn it off and on as you want. Electric fans may work but you wont get a lot more cooldown. Other issue you could have is gunk in the radiator. May have several cross tubes stopped up.
T2C
Arizona
Thanks. Going to do the flush and refill first, and hope that works. Will look at the fan clutch lines tomorrow, and see what i need to do for that. If necessary. Suprman: will remember you for the fan, if neither of those work. The consesus of those affected by money going out was to flush, and change the fluid first, as it needs to be done anyway.
T2C
Arizona
Meow are you saying to link the two hoses from the shutterstat together meow?
simp5782
9,339
Mason, TN
Yes. They are both #6 jic male fittings. You need a # 6 connector they are about $3.
Sent from my SM-G935P using Tapatalk
simp5782
9,339
Mason, TN
I seem to remember the fan clutch defaults to locked up with no air on it. am I wrong?
The stutterstat receives air from the treadle valve. It is stuck there until the temp gets to 190 then the stutterstat spring releases and lets air flow thru to the fan clutch that in turn locks the fan up. The reason people blow radiator caps or hoses is that the stutterstat fails and pushes air into the cooling system from that treadle valve.
T2C
Arizona
Thanks. With all the help I've gotten here, it's just a matter of starting with the simplist, and working out. Thanks everyone
simp5782
9,339
Mason, TN
Thanks. Also thinking of getting a plug to thread in where the stat is. Thinking it may leak coolant from the ports. Am i correct, or is that unnecessary?
It is rare. It is just a half inch plug.
