How to add an EGT gauge with a PID
Reworked LMTV
1,169
TN
Avoid silent death-How to add an EGT gauge with a PID
Here is an inexpensive way to add an EGT exhaust gas temperature gauge. I will be increasing the accuracy of this unit by adding a cold junction compensation mechanism. This particular unit I already had and it reads in Celsius. You will want to get the appropriate voltage PID and there are probes available in Fahrenheit. I paid about $25 for a 120v pid and probe on eBay. Have inverter.
https://youtu.be/t29zQftbcHQ
https://youtu.be/bOCtLQhGkaE
Tapping the exhaust manifold was fairly easy. Do not buy the glow shift drill 1/8 npt drill bit and tap set from Amazon! The tap will break and you'll have to tear the turbo off to get the chunk out. Buy a very good quality tap and drill from somebody like Fastenal.
Dwnorton1
23
Healdton Oklahoma/ SOOK
Great idea. After looking at yours I may get one and use the contacts function as alarm contact to give audible alarm at high setpoint. Fleabay has multiple choices
Reworked LMTV
1,169
TN
The 3116 and 3126 are good engines, but they do not have the water cooled cylinder sleeves. Therefore, they are less forgiving of intense exhaust heat which could easily lead to a dropped valve, melted pistons, etc., which leads to a catastrophic engine failure.
Awesomeness
1,514
Orlando, FL
The 3116 and 3126 are good engines, but they do not have the water cooled cylinder sleeves. Therefore, they are less forgiving of intense exhaust heat which could easily lead to a dropped valve, which leads to a catastrophic engine failure.
Under what circumstances does the "intense exhaust heat" happen? Is this something that creeps up and causes failures? Is it something you have to be careful of when doing more heavy use, like towing heavy trailers? Should everyone be interested in putting on these gauges (and why aren't they there in the first place), or just certain users?
coachgeo
3,405
North of Cincy OH
Pretty much it is for anyone who has turned up their IP or similar that takes the engine outside its OEM parameters should consider installing and EGT Guage. Same if your pushing the rig on the end line of its parameters often then one should consider it. For everyone else with careful long term recording and careful data reviews, you might can catch some issues before your seat of the pants / heavier foot needed might feel it.
98G
Former SSG
4,288
Lugging it also causes high EGTs.
Long steep uphill climbs with a heavy load risk elevated EGTs.
In theory, stock settings won't take your EGTs beyond tolerable limits.
High EGTs are bad because diesel pistons tend to be made from aluminum alloys with a melting point of 1200ish.
(George just said most of this. Not sure why I feel obligated to repeat it)
Reworked LMTV
1,169
TN
My engine is stock. I think that it is particularly important to watch the temps on a 290 hp 3116 or a 3126 at max hp. There is a somewhat linear relationship between boost and EGT's, from what I have seen. The temp may not go down for 3-5 seconds of backing off the throttle.
I am still experimenting and will add additional electronics to improve the accuracy of this set up.
ramdough
1,729
Austin, Texas
So, what exactly are you using the PID function for?
Or, are you just using the temp gauge reading to tell you to lay off the skinny pedal?
Sent from my iPad using Tapatalk
coachgeo
3,405
North of Cincy OH
Neither of the videos are available?
just a heads up to help you out....... it helps to quote a post so:
1. everyone does not have to cruise back thru all the post to see what a poster is referring too.... and
2. Very often if one quotes a thread..... the member whom was quoted ... will get an email notification about them being quoted.
have (another) great day rainy OH day
Ohiobenz
267
Seville, OH
I guess I assumed that when its only a 2 page post (so far), and the very 1st post by the OP is the only one with a video, this would be easy to figure out....
Let me try again...
Ohiobenz
267
Seville, OH
Even copying and pasting the url directly into chrome doesn't work for the video.
coachgeo
3,405
North of Cincy OH
Let me try again...
sorta but nah; not really, cause often a user settings are to go directly to last post of newly responded too threads thus user has no clue; without hunting, if reference is only one page back or 90 pages back
