94' LMTV Wiring Diagram Help needed
beltfed1934
36
Burnet, Texas
Can someone tell me what the P39 wire/connection is for? Mine is unplugged-not sure if it's supposed to be that way or not, and I cant find it in the dang tm's to save my life!
TIA,
Austin
coachgeo
3,463
North of Cincy OH
TIA,
Austin
You passed right by the TM's to get to this forum. Go back to the opening page..then seek and you will find your treasure .....Under .the ..... Technical Manuals (TM's) forum (Sorry just got thru watching Pirates of the Caribbean )
Update....... my bad miss read your first post... thought it read you could not find the TM's. Missed that one little word IN lol. You know..... Pirates can't read worth a shiat:gimp::cookoo::wink:
utahpow
Orem, UT
"Its so passengers can get the drivers attention" per Suprman: https://www.steelsoldiers.com/showthread.php?167087-Troop-seat-alarm-on-a-m1078&p=2004291&viewfull=1#post2004291
"Troop Transport Alarm Cable" from TM 9-2320-365-20-5 (m1078_TM 9-2320-365-20-5.pdf), page 20-466, and also in all the other TMs that I have.
Sorry I don't know first-hand myself. But a bit of searching in the PDFs and Google did the trick for me. Enjoy!
More info: http://trucks5tonops.tpub.com/TM-9-2320-366-10-1/css/TM-9-2320-366-10-1_167.htm
beltfed1934
36
Burnet, Texas
Thanks! Spent 15 min in TM trying to figure it out but didnt see it for some reason.
KGBruce
High Ridge, MO
I've also got a migraine trying to find the electrical and air schematics for my M 1078 A0! I've got so many systems to figure out on my new purchase it's mind boggling! Currently trying to rewire the stater solenoid after a small electrical �� A little advice… Install both 24 V and 12 V power shut off's at the battery box! Mine is a 98 model which did not come with the shut off's ! Bad idea! I'd love to get a good pic of how the starter solenoid is wired in in relation to the starter.
firefinder
10
Macon,MO
The “fold out” schematics are not listed in the table of contents. Look at the end of the tech manual. For the FMTV series, I believe they are at the end of the parts manual.
spankybear
911
WA
If you didn't know pressing control f at the same time on a PDF is a search. It will drop down a search box on the upper right corner. I use this all of the time
