Volvo740turbo
- 0
- 0
- St.louis missouri
Mine would try to melt the headlight fuse often....after the new starter and removing the reisitor I didn't have an issuse..problem is when the 24 to 12v resistor goes bad it sends 24v to everything that only runs 12 or in my case that's what happened...i believe the starter began the process as it was junkWould this cause a charging issue I've replaced both alternators still not charging also keeps blowing headlight bulbs and brake light bulbs,when heater fan is turned in it blows the fuse
Im not sure if it would keep the alt 1 or 2 from trying to charge but if it's already started to fry the electronics it's possible
