Just finished watching some YouTube videos about doing a leakdown test. 0%-10% is Good -- 20%+ is questionable. Its almost on 20%, looks like the rings are leaking too much. Cant hear any thing threw exhaust or intake, I can hear air in valve cover when I take oil cap off it.
Leak through gasket
1. Cylinder head improperly tightened. - Think I would noticed it leaking, than again.
2. Broken cylinder head gasket. - same as #1
Leak in crankcase - Flow chart
1. Poor quality lubricating oil - been using brand name 10W30 looking in yanmar manual I should be using 20W40 15F - 100F it gets warm where I live. 10w-30 is good for -10F-85F.
Can improper oil grade cause a leak like this?
2. Piston Ring Sticking - No way of telling until it pulled that I know of.
3. Broken/worn piston ring - same as #2
4. Broken piston ring lands, Worn ring groove - same as #2
Even if proper grade of oil fixed this which at this point I think wouldn't help much, the cylinder walls are probably built up with carbon and the piston rings and maybe the piston its self bit the dust.
