- 902
- 308
- 63
- southeast Indiana
To date I have flipped 17 lunettes on m105a2 trailers and have never run into any problems like I read about on here. I use two big combination wrenches to do it. A 1 1/2" of course to turn the nut and any of a number of large wrenches (1 5/16" up to 55mm) that I put behind the nut that acts as a backstop to drive the nut against when backing it off the threads so it applies pressue against the lunette. Only two of them did I have to use a hammer on and those took only about 6 or 8 good whacks as I turned the nut to apply pressure. I have never had to use heat or penetrants for any of them.
This procedure has never failed on any of the ones I have done and I live in the middle of the rust belt here in Indiana so you can bet some of them were pretty crusty inside.
