myridge
- 0
- 0
- Potosi/Missouri
I picked up a GL auction MEP-803a last week and just had time to mess with it last night and cannot get it to start.
I charged the two Optima batteries and checked the all the fluids and tried to start it.
I removed the filler neck and looked in the tank with a flashlight and seen what appeared to be some shiny metal flakes in a few spots in the tank so I vacuumed the tank out with my extractor and added 3 gallons of fresh diesel. When I flip the switch to Prime & Run/w Aux or Prime & Run I can hear the fuel pumps doing their thing. I select Prime & Run and let it sit for 15 seconds or so and then choose Start and it cranks over for 20 seconds or so and never starts. No warning lights come on unless I press the test button and they all light up.
It has 1/4 tank of fuel and good batteries.
NOTE: There is a wire that was pulled from its connector near the dead crank switch. I still need to review the TM & OM to see what this is but I did reconnect it. Also, there is an extra wire that is zip tied up and doesn's seem to go anywhere is this normal?
Also it looks like the shroud has been bent and pulled out away from the fuel pump. I am guessing this is why it was decommissioned and listed on GL and I got it for such a good price but any advice to help me get it going would be very much appreciated.
If it helps its a 2003 Fermont MEP-803a with a Tier 2 reset and has 425 hours on the clock. The fluids look new and pristine.
My next steps were to order a new fuel & oil filter and inspect both the old filters closely when I changed them and changed the oil even though it appears new.
