Pulse tech distribution system.
Comes with manual reset 24v breakers and auto 12v
Same size as ato fuses so those can be used also
Pics on my thread Juans'm998
I bought one of those sets (PDU/battery tester) and already have two of the pulsetech 24V solargizers.
If you have one added, is the wiring from the solar panel DIRECT, or does it go through some type of charge regulator like the one that comes with the pulsetech unit? I'm kind of assuming (based on pouring through the online pulsetech catalog and other images) the wiring is direct, and the module/battery tester does the charging/pulse desulphating.
ALSO, and anyone can chime in here, What is the amperage output on the 12/14V side of the alternator? Might be on the regulator, I haven't scrutinized it yet, it's still in the box and freaking HEAVY.
I'm thinking 8gauge cable for about a ten foot run would be about right for up to 40A output (105c rating, conduit, inside engine compartment) per my Wiresizer app.
That's a lot of amps.
anyone?
EDIT: Erik's Military Surplus data on this alternator says 50A 14V.
Wiresizer shows 6G for a 10 foot run w/ 2-3% power drop (4AWG for 1%).
Thanks in advance. I'm about to go all-in and install the alternator, hook up the PDU/solar panel/battery tester, have a 35AH gel cell for under the rt rear pax seat, need charging cable).
