cucvrus
- 10,132
- Jonestown Pennsylvania
Do your sway bar bushings look like this? These are the replacement sway bar bushings from Energy Suspension. You can buy the on Amazon of course. These are easy to replace. I replace the 4 - 7/16" bolts washers and nuts that mount the sway bar to the frame up front. On the spring plates I use the OEM bolts and washers over. The bolts must have a flat washer on the outside and the inside of the sway bar. Energy suspension sends a small tube of lube and it has enough to lube the bushings and the bolts to reinstall them. Good Luck. have a great day. I hope this is helpful.
