- 290
- 20
- 18
- Odessa/Texas
I was going to transfer one wire by one from old speed control to new speed control, and also label them as Afghan suggestsDon't do it running.
Sorry, couldn't resist. The main thing is to make sure all power is off before doing the work. Hopefully all the wires are clearly labeled. One of the tricks I do is to run a strip of tape down both sides of all the wires which helps keep them in order.
Double and triple check to make sure all the wires are in place correctly.
Once you have it up and running go through the TM and verify that the mechanical governor on the engine is adjusted properly THEN adjust the electronic governor.
I will do soIf it were me I would pickup some wire labels at home improvement store and label the wires at the boot of connector.
Hi guys, back from holiday in NL (they have almost no mains power outages due to buried mains) and I put the governor in today - did the calibration as per GAC website:I have started to jump in here three times. Wrote something up, and deleted it. I concure 1000% with Dieseladdict. But the one thing I have waited to add, is this. Unless you have wired the original governor yourself, check the wires against the wire diagram. I can not count the times I have had it happen to me, or I came in behind some one who did it. All it takes is one second of non concentration, and two wires are in the wrong place. Then the next guy comes along, and repeats the mistake. Take the time to look at the wire diagram, print a copy off and have it at hand. Can't hurt, is probably over kill, but I learned the hard way. Check everything. Trust nothing. THEN when you are done, your done. Just my two cents.
If the target is off the magnet the set will start/run for a bit regardless of the position of the RUN/STOP switch....Also, I had a weird thing happen, I forgot to move the operation switch from stop to "RUN" (still recoil starting) but the generator still started...! How could this happen?...
Thanks for the clarity! The no fuel fault design seems a bit redundant then!If the target is off the magnet the set will start/run for a bit regardless of the position of the RUN/STOP switch.
One of my 831's wouldn't shut down even with the switch in the STOP position because of a No Fuel fault.
With a No Fuel fault power is dropped to the governor controller.
