30D36R Wisconsin Robin Generator
rustystud
2,988
Woodinville, Washington
Does anyone know who sells parts for the Wisconsin Robin engine WRD1-270 used in the 30D36R generators ? I want to get a spare fuel injector and fuel pump. I have looked for a couple of days now and all I find is that the parts are discontinued.
Thanks for any help.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
I have the manuals for it. I have a parts set in one of the trailers but it has either a bad injecor or pump. Can't recall.
rustystud
2,988
I have all the manuals. What I was looking for was a spare injector and possibly a spare pump. I plan on using this machine as a "back-up" to my main generator. At night my power usage goes so low that I'm only using about 1.5-2KW . The MEP-002A starts to wet stack over night. So during the day I would use the MEP-002A and then at night switch over to the 3KW 30D36R unit. I have a MEP-016D I'm working on right now. Engine runs great but the electronics was trashed. I might just buy a whole new generator head from "Winco" . I never really liked the 10 wire generator set-up. When your running 240volt your only getting around 2500KW instead of the full 3000KW.
rustystud
2,988
Rustystud; Were you ever able to locate a replacement injector pump?
No. This motor was just left on the side of the road to rot by "Wisconsin Robin" . No support from them at all. Most small motor parts places just have the basic stuff like filters and a few gaskets. I've pretty much given up on this engine myself.
Maybe later I will try and match some piston rings for it. It does still run. In fact it runs will well until you give it a load ! Then it just dies fast, blowing smoke like crazy !
