After seeing a couple of rollover pictures I started to get a bit concerned. All the photos I have seen the cab is bent and often times crushed. Has anyone looked into a roll cage or considered adding extra tubing on the outside and possibly making a roof basket (for more storage)?
I will most likely have a Headache rack/ROP* for sell when I remove the one the fellow I purchased from built. Granted it would be cheaper to have new one built near you then shipping this one. The rack is just behind my cab in my present user image. Was originally going to add a bar, maybe even a section for FOP* to the top of the ROP* to build it up higher a total of about foot above the cab's top along with some Triangulation. Also considered ExoCage on/Around and/or in the cab to match
As was mentioned earlier in another thread... a ROP for these 18,000lbish rigs would have to be one **** of a big chunk of Fabrication to prevent a crush. Less as big lesson a crunch but still that would be no ordinary tube. Then there is the problem of working around the cab lift or upgrading the lift to handle a heavier cab. All this gets complicated quick.
For reasons you describe is why I went with an Ambulance Box for the future upgrade to a camper. I want a camper.... and want a ROP so sorta get both in one swoop cause the Box is strong enough to act a bit as a ROP for the cab. Cab will still get damaged... but not near as much so keeping the passenger/pilot safer. To be honest think I will put Cameras up front and other places then encourage passengers to ride in the box where they can watch where we are going, coming from, or side views, on a view screen, phone or Tablet.
*ROP (roll over protection), FOP (Fall on Protection) ... AKA Tractor/Unimog Lingo
