Rene M
- 2
- 0
- Houston, Texas
So, i have been hard at this for a few days but just cant seem to wrap my head around it. I have no power or ground to the fuel solenoid. Not in crank or run mode.
now i do have power to the engine temp, and the oil pressure switch all function and i good good power transfer . Still no power and i have stared at the schematic so long its just a blur.
power goes out from the master , runs through the temp, oil pressure switches and then it goes? clearly it comes back in to the control area but to what. im at a loss.
Also, i get power to my hour meter gauge and charging gauge only under cranking not under run mode.
Im sure the answer is staring at me but i fail to see it.
If, i run a bypass to the solenoid both positive and ground, the engine starts like a dream and runs great. just cant get past this. i want the unit to run with the safety system intact.
And yes the emergency shut down works and is not engaged.
I have helped a lot of people over the years on here now, i'm asking for help.
