- 16,494
- 23,483
- Burgkunstadt, Germany
If the plastic is still on them, then they have never had acid in them.
Thats great to know... free batteries that I thought were dead! One makes no noise when moving, the other sloshes a bit. I would have assumed there was no liquid in them if the plastic was retained. Thoughts?If the plastic is still on them, then they have never had acid in them.
I am not even sure which machine I pulled these out of... maybe one of the 802As I have. I opened the top one the sloshy one yesterday, and it had no odor (and what appeared to be a slight oil sheen)... so I am thinking that it is water. Need to figure out a container to dump it into, for testing purposes (as I have no way to pipette out some for testing).What does asid react to? Baking soda? If so, take a few drops and put it on a small pile of baking soda. See what it does. If it doesn't react, then maybe its water? Normal, when they come new, the cells are covered with a yellow, (I think) plastic to keep out moisture and dirt. Only way to find out is try it. Was the set dirty when you got it? Or look like someone had pressure washed it?
Plastic straw with finger over one end?(as I have no way to pipette out some for testing).
