They were probably the same shockI've had the Rancho 5000's & skyjacker 7000. I couldn't tell any difference between the two?![]()
Already a little older the thread
but maybe my questions will be answered anyway.
I would like a 4 "lift for a M1008, Skyjacker leaf spring front and blocks rear.
Would like the suspension a bit firmer because I drive more road ... 95%
The Skyjacker shocks are probably a bit softer, have currently mounted a 2.5 "lift with hydro shocks from Skyjacker.
Now I read more often about Tough Country HD and Bilstein shocks.
Are the Bilstein or Tough Country HD shocks a bit tighter?
And what damper did you mount at the rear if you mounted Bilstein or Tough HD on the front?
Would be nice if someone has parts numbers for me, I would like to order from Summit.
thank you for your help
