KAT MAN
- 0
- 6
- California
hey guys
has anyone swapped a Catperillar D-7155 transmission into a M931?
Thanks
Thanks
https://www.steelsoldiers.com/showthread.php?169592-Simp-s-Cat-7155-Swap-into-a-M923A1 He's installing it into a m923a1
Sounds like a challenge....KAT MAN!Won't fit in a M929,930, 931, 932, or any variants there of. The wheelbase is t to short.
Sent from my SM-G930V using Tapatalk
thank you for sharing your knowledge thats good to hear that I can adapt it to it.Both that engine and transmission were available in civi trucks, gotta be a few of them out there set up that way. They will work together fine. The medium/heavy duty market has things standardized unlike the 1 ton and lighter market where each manufacturer has their own setup (Chevy engine wont bolt up directly to a ford trans for example). In this market it's all SAE 1,2,3 bellhousings and each engine/transmission is adaptable to that.
No not what I was posting about! The transmission won't fit goobers. Almost any medium and large truck motors will fit.thank you for sharing your knowledge thats good to hear that I can adapt it to it.
I should have clarified the 3406 is for another project but it would be a cool project to get it in one of these military rigs
I love a challenge and having something unique so it sounds I need to make this happen
How about if the a transmission hump is fabbed up?No not what I was posting about! The transmission won't fit goobers. Almost any medium and large truck motors will fit.
It wont fit in a short wheel base truck and be able to use the transfer case. If you use the transfer case your one driveshaft will only be about 8 inches long. Almost impossible for a companion flange setup. only other option would be to move the bogie back and thats alot of work. You might as well anticipate about $2500 for everything including the transmission. Even more if your not a fabricator. Some parts you would need can be hard to find.How about if the a transmission hump is fabbed up?
