Missing Relay
HelluvaEngineer
82
Atlanta, GA
My Voltmeter has been dead since I bought my truck a couple of months back. I know it worked when I test drove it. I took the plate with the relays and starter relay off and one of the relays is missing. I think someone was monkeying with them before I bought the car (it had all kinds of starter issues.)
Oh, my gen 2 light is on too but that may be coincidence.
Anyway, the P/N is Bosch 0 332 204 151 on the one that is still there. Marked 12V 20/30A. Is there another P/N that is preferred?
Also, how do I tell the Gen2 relay from the Voltmeter relay? Are the sockets and relays the same?
HelluvaEngineer
82
Atlanta, GA
I did find this on other threads. Looks like they are two different relays.
Bosch
12v
20/30A
0 332 204 151 (Bosch pn)
12033862 (GM pn)
5 blade terminal connection
Bosch part number 0332204151 interchanges with the NAPA part number
ECH AR272
doghead
4 Star General /Moderator
1,177
Your truck has not been converted to 12 volts, has it?
doghead
1,177
I wasn't asking about the relay.
HelluvaEngineer
82
Atlanta, GA
Well I found the Gen2 problem. The Alternator belt must have broken. I'm trying to find the correct length now. If anyone happens to know it would be a huge help. I'm assuming there's no match on that one for the Blazer equivalent.
NM: Passenger side alt- Gates# 7483; Dayco# 15490
HelluvaEngineer
82
Atlanta, GA
Helluvaengineer, by any chance, have you looked at a parts manual for the belt?
For the belt I was able to find the Gates PN (posted above) by searching the site. It's a little quicker than searching the PDFs and then trying to cross reference the old part numbers.
Sorry, I was trying to get some stuff in shape quickly today - Atlanta is in panic mode due to this storm coming through. We're running out of gasoline but plenty of diesel so I was trying to get some things fixed in the CUCV today.
