Olympus
- 0
- 0
- Cape Girardeau, MO
Hey guys, I've been wanting a 5-ton for several years now and I can never get the wife on board. For the most part, it's just been a "for fun" toy to play with and maybe to drive in some local parades. But now I may have a situation where I could actually have a use for the truck. That is if it's even possible to use the truck for what I'm thinking.
Here's the deal. I own a large hunting property that's 25 miles from my house. The property is about 2 miles down a rough and neglected gravel county road. I recently bought a bigger tractor to use mainly because of this property. The tractor weighs 4500lbs and I currently don't have a trailer big enough to haul it. I have a 12ft trailer with a 3500lb axle. The tractor with the front loader attached will just barely fit inside the 12ft trailer, but it overloads the axle and my truck is only a 1/2 ton so it's not exactly a light load to pull through the hills and curves on the way to the property. My neighbor has a 16ft car hauler trailer and the tractor fits great and with a brush hog just overhangs the back of the trailer a couple feet. Problem is the neighbors trailer doesn't have safety chains, doesn't have working lights, and doesn't have trailer brakes. And positioning the tractor on the trailer either gives you a TON of tongue weight that squats my truck really bad or if you turn it around backwards, it's too much weight on the back of the trailer and wants to fishtail something dangerous. So I've been loading it tongue-heavy, but that's gotta be hard on my truck.
So I'm thinking I can spend $2500 on a new 16ft tandem axle trailer with trailer brakes or maybe I can pick up a decent M923 at auction for about $5000 and use the bed to haul my tractor back and forth? That gives me a legitimate use for the truck and it could fit a need that I currently have with getting my tractor back and forth to my hunting property. I'll attach some pictures of my tractor so you can see what I'm working with. Like I said it will just barely fit inside the interior of my current trailer that's 6.5ft x12ft without any attachments. And the loader frame and bucket are easily removed and gives another 3-4ft of room.
So do you think I could use an M923 in this manner?
//uploads.tapatalk-cdn.com/20170918/f7bea5a9f34dd1de6723e64be0b364ea.jpg[/
IMG]
[IMG]//uploads.tapatalk-cdn.com/20170918/2fcda6855f8819513f8f0088ea618732.jpg
IMG]
