- 3,328
- 1,295
- The actual midwest, NM.
Led Zeppelin? It comes free through the air on several stations.were can I get it for my truck
My hearing protection has Bluetooth connectivity. Led Zepplin is one good choice.Down load it and get a good portable Bose head unit. I carry one in my cab of Terminus M1009 when ever I go wheeling. XM and Robert Plant as my copilot. I am a traveler of both time and space.
https://youtu.be/hW_WLxseq0o
OK I missed up and do enjoy what you guys are sending and a big thank you too.Led Zeppelin? It comes free through the air on several stations.
That is what you have to do because it's grounding out buy the gauge case.It seems that adding the mechanical temp gauge to the same plate that the GEN gauge is in grounds the plate with the capillary tube to the engine block causing the GEN gauge to come alive. When I remove the temp gauge from touching the plate, the GEN gauge turns off. I wonder if that means that there is an internal fault in the GEN gauge? It works properly, otherwise. I may just have to insulate the GEN gauge's body from grounding to the mounting plate.
Hasn't happened yet. I think I have 4 trips to Rausch Creek, Many more to the power lines, And a trip to trucks gone wild. outside of routine maintenance and fixing the standard issues associated with 34 year old vehicle. Like the Ever-ready bunny still going. Life is a highway I want to ride it all night long. Terminus M1009 was being used for what it was made for. And if it were not for me it would be a Toyota or a refrigerator. 2 vehicle rows away from the crusher when I found it. Had it not been for the snow plow it would be gone.Ahhh
Nothing like a day 4 wheeling to break down and/or tear something up!!
You did not miss it yet. This is NOT till next month Saturday October 21, 2017. All is well you still have time to get there.I wish I was there to have some fun but had to work Sat. and Sun. is the day I have to clean up for the next 6 days of work.
I well try to plan for it but then I have to make shure I don't brake something there.You did not miss it yet. This is NOT till next month Saturday October 21, 2017. All is well you still have time to get there.
