I pulled the trigger on a new 3.08 ring and pinion to replace the damaged set in the 8.5 GM 10 bolt axle in the 1986 M1009.
The old R&P had rust damage, pitting on the drive face, and a gov lock carrier showing signs of damage to the locking mechanism.
I thought it might be interesting for anyone else contemplating a similar project to see the cost of a complete axle overhaul/upgrade of a stock M1009 10 bolt.
I will retain 31 x 10.5 x 15 tire size with a New set of BF Goodrich KM2's to replace the cracked tires my M1009 came with.
I already have a 1976 K5 Blazer on 33's and 3.73's and I wanted to keep this 1986 M1009 on 31's but with the punch of fully locked differentials to match.
Gear Ratio;
New 3.08 Ring and Pinion by Richmond.
The 3.08 ratio is perfect for the M1009 on 31's for economy and the NP208's low range makes off-road still a breeze.
Might have gone 3.42 but then I would have to swap the front gears and they are pristine and already locked up with a Spartan locker.
However, I am upgrading to a 30 spline Detroit Locker and Yukon gear 30 spline axle shafts.
The last ring and pinion sets I did the hard way.. a splitter and a two jaw puller.
I got smart this time and bought the clam shell carrier bearing and pinion puller by Yukon Gear.
Things I learned;
Prior to 1988 the GM corporate 10 bolt axle has a 28 spline carrier and axle shafts but a newer 30 spline carrier can go right into our older housings.
The newer 30 spline axle shafts can be swapped into our old M1009's along with a 30 spline carrier.
The aftermarket carrier requires HD carrier bearings in order to fit the Detroit locker (or Eaton limited slip, or True-trac etc).
What does it cost to completely rebuild or upgrade a GM 10 bolt axle these days?
Part numbers and prices.
Here you go;
Detroit Locker GM 10 bolt 30 spline 8.5/8.6 DTL-187C148A $674.99
Richmond Ring and Pinion 3.08 RMG-49-0017-1 $230.49
Summit racing dial indicator & magnetic base SUM-900016-1 $ 29.97
Yukon Gear outer axle bearings and seals YGA-10001(1559) $ 49.10
Yukon HD axle overhaul kit with HD Timken YGA-14088 $211.42
Yukon Gear rear axle shafts 31.5 " 30 spline(2) YGA-21266 $350.98
Yukon Gear c-clips (2) YGA-21266 $ 8.54
Yukon Gear Carrier bearing puller YGA-56072 $519.86
Free shipping
Total $2,075.35
I am providing all the labor.
Now I just need the snow to hold off long enough for the parts to arrive and allow me to tear into this axle.
I'll check back with pictures when I get the parts and begin the project.
Gear Ratio;
Things I learned;
Here you go;
Free shipping
Total $2,075.35
