Gunny456
- 0
- 0
- Harper, Texas
I am a new guy to this forum. I am trying to do a frame up restoration on a M1044. It has the correct doors and old glass in it. The glass is a total of 5/8" thick but it has 3/8" of glass and what appears to be a 1/4" Clear Lexan piece laminate on the outside of the glass. The rubber gasket groove is also 5/8" wide. The window aluminum channel is 7/8" wide inside. I can only seem to find glass 3/8" thick and can't locate the 5/8" thick laminate glass. Can anyone guide me on this please?
Also the front windscreen appears to not be correct as it looks as though someone installed standard glass in it and it wobbles back and fourth. I surmise the correct glass should be thicker? What thickness should it be?
Thanks in advance for any help on this.
