5 Ton Dimensions
Artisan
227
CDA Idaho
My 5 Ton is in Idaho, I am in L A.
The book says an M925A1 has a wheelbase of 179" .
I am correct that dim is from center of front axle to center of Rearmost axle yes?
So if tires are 49" in diameter the dimension from the front of
the front tire to the rear of the rear tire would be 19' correct?
Punt
simp5782
Feo, Fuerte y Formal
9,492
Mason, TN
With 11.00s its 206 from center of front tire to center of rear tire. So adding the difference on tires a little over 19ft
Sent from my SM-G935P using Tapatalk
gringeltaube
Staff Member
2,641
Montevideo/Uruguay
No, for our 6x6's the "wheelbase" as found in the TM's is always measured from center of front axle to the center line between the two rear axles.
Artisan
227
CDA Idaho
Hmmm, so if I have a 20' long tilt trailer deck it will be cutting it close
I assume w/o some semi - serious math work.
THANK U Gringel...
(Capacity is 27200 pounds.)
Artisan
227
CDA Idaho
Well it's an A1 w/ 1400R20's so looks lke were pushing the envelope.
Understand the front tires will go past the front edge of the trailer a smidge,
there is a 4" x 4" piec of angle iron that is adjustable at the front sooooo...
THANK U Simp!
simp5782
9,492
Mason, TN
THANK U Gringel...
It will fit on a 20ft. My deck is 19ft7in and a 5ton will fit in it.
