cucvrus
- 10,431
- Jonestown Pennsylvania
1476.375 mm for our Metric friends. Thank you.58-1/8 Inch
Would you mind elaborating please?Even with the Gen 2 belt water tight. I get a weak sounding drone squeal after start up. It makes the sound only during the cycling of the glow plugs in the after glow cycle. It will do it very faintly for the first minute and then it's gone. I have my CUCV hooked up stock in all ways. I know when the resistors are by passed that eliminates the after glow cycling of the glow plugs. Just an observation. Charge rate is normal and vehicle starts and runs great. Just a slight load on Gen 2 after cold start.
Yep.I don't have a clue. Other then when the resistors are by passed it effects the cycling after glow of the glow plug system. I am not an electrician and never had any out of the ordinary maintenance problems with the glow plugs system as it is and was from new. So I only maintained it that way. I did buy a few CUCV's that had push buttons, toggle switches and bypasses and still started poorly. Once I removed all the gadgets and switches and returned it to TM OEM spec's the problem went away. Each one had it's original failure still present that triggered the hacking but still not repaired so someone bypassed the system. I still have a GM card in the one I am describing. Probably never even removed it. I do have some new cards that I bought here on this site. And a few New Genuine GM cards. Haven't needed any lately. I think something is reading voltage that has to do with the resistors. But what do I know. I pick things up and put them down all day. Have a good one. Let the scientific electrical people elaborate further. Someone????
Ok, then I'm reassured.I thought I was you somehow stepped on the feet.No I never meant anyone specific. Just saying a few of the things you try are not going to be right for others. And when they try your ideas they never work either. You done nothing wrong. I am glad your belts work for you and hope everyone finds things that work for them. They are not mine so I can only suggest and offer to help. You did nothing wrong. Have fun.
When I plug; Gates XL 11A1460 into Google search, I get Gates belt 7575.
When I search Gates 75 belt, there is an A75 belt.
Well calculated.1476.375 mm for our Metric friends. Thank you.
I cheated. I googled it. BetrügerWell calculated.
I have steel toed boots. I get my toes stepped on so often. I don't even take notice anymore. Wears the leather thru now.
Yes you are right.I guess it is tough with the language barrier.
Thank you.You are all good. No problems here. I enjoyed your posts so far. It is great that you have a CUCV in Germany.
Yes, I will do that.Take care enjoy. Keep your V belts tight and dry.
What I am noticing after restoring the glow plug resistor pack is louder glow plug solenoid engagement and more noticeable solenoid engagement during afterglow.The after glow period is based on the GP temperature sensor resistance and the voltage on the orange GP voltage sense input.
If the engine is cold the resistance is high, as the engine temp increases the resistance gets lower and the card will not need to perform as long of an after glow.
If the voltage is higher than designed on the GP voltage sense wire, the card will cycle the GP relay to limit the possibility of damage to the glow plugs.
So a combination of the 2 variable inputs to the card will determine the necessity and the duration of the after glow period.
I wouldn't expect it to be the same, if you reread AC's post above, the variables would have to be the same between both systems for similar results, not sure that's possible.Not the same. Mine all go back up to green right away after starting and then you see it drop a bit and then back up in green and then back down again. It does it about 4 times and takes about 30 45 seconds to complete. It will slowly go all the way green to the notch each time. Yours stayed down in the yellow area most of the time. Bighorn. Can you video the action I am describing? I also hear a solid clunk of the relay on the firewall every time. You have 2 volt meters?
