DUUANE
- 122
- 43
- Qualicum Beach BC
Hi everyone USMC 00-08 has asked me to start a thread as repository for information regarding the replacement of the stock 302 gmc military distributor with a civillian unit as some parts for the military are no longer in production.
I will try and cover distributor interchange. I have read that other members have used a distributor from a chevrolet 235 six with success. There was a change in the style of hold down clamp but i will have to investigate further. I have one in a 57 chev school bus chassis and another in a 54 chev 3/4 ton so we can see if there is a difference between light and medium duty units.
I will assemble some manufacturers and part numbers for under the cap electronic ignition conversions. I used this on my 55 Dodge M37. I built the truck from a bare chassis and couldnt find a military engine but was lucky to find a good civilluan 251 so thats what i went with.
Ther electronic conversion was the best 50 bux i ever spent. Easy fast starting, more power, and more range. Never had to mess with a set of points again in the bush. Pure joy.
The only downside is they are a little sensitive to high voltage..so if your voltage regulator packs it in and your're on the highway at 3000 rpm making 20v (in a 12v system) it will zap the transistor in it and youll have to replace it.
The conversion replaces the breaker points plate in the distributor (not all the kits are like this but the one i like best does..read on.) And has a magnet setup that presses onto the distributor shaft and lives under the rotor. Its a hall effect switch and flying magnet setup. The other style is an infra red led, a photo cell and a plastic disc with slots molded i to it to allow the led and photo cell to alternatly "see" and "not see" each other. I wasnt really impressed with the quallity and accuracy of the molded shutter wheel. So i went with the hall effect unit.
Because it replace the whole breaker point base plate i was able to rebuild it, gap the points, and drop it in a ziploc bag with a pouch of sillica gel and toss it in the glove box as a saftey i could change out on the side of the road should my voltage regulator pack it in and quit.
I will also try and assemble information from other sites on modifying a later model GM HEI distributor for installation as an assembly.
