Aernan
- 19
- 18
- San Jose/California
Is there a remote start/stop somewhere or do open the door and use the main master switch?
If you have an A1 yes there are engine compartment switches to start/stop the engine. If you have a 3116, then no.Is there a remote start/stop somewhere or do open the door and use the main master switch?
You can tilt the cab with the truck off as long as the air tanks are full.Sounds like I need to climb into the cab and manually turn off the truck after tilting the cab.
Do you have a picture to post? Online I see 3 switches above the area you describe, but don't see it on my truck. 2001 m1088 2010 bae rebuild. Either my a1 doesn't have it, or I'm looking in the wrong placeIf you have an A1 yes there are engine compartment switches to start/stop the engine. If you have a 3116, then no.
Does your truck go the full way with tanks full engine off? I can only get 3-4 ft of tilt. Wondering if I have a leak somewhere or an inefficient pumpYou can tilt the cab with the truck off as long as the air tanks are full.
Yes, I can lift my '97 M1078 cab fully up, and fully down, almost twice, on one full tank(s) of air. That's also what the manual says is to be expected.Does your truck go the full way with tanks full engine off? I can only get 3-4 ft of tilt. Wondering if I have a leak somewhere or an inefficient pump
I lifted my cab with the engine running and then switched it off and lowered the cab. I'll try a full cycle next time.ok I'll give that a shot. I just got a pump handle in case the air/hydraulic system does not lift it.
On one of my engines it was an engraved aluminum plate, about the size of a dollar bill. On the other engine, it was a paper label with a clear "sticker" over it, about the same size.There is some kind of smog cert on the valve cover. I guess I will need to pull the air pipes off to fully inspect the top. Is it a printed label or stamped in?
