- 1,651
- 1,665
- Nova Laboratories, WA
Switches came from a member here..First off--you're my keyless ignition hero. Next, where did you get the goods to do it? I was going to use a momentary rocker with a flip-up cover with a label that says "ARM" and a push-button for the starter that says "FIRE"--kind of going on a weapon theme...BUT, I love staying with the military theme. I had even thought about putting one of the M-Series push button switches in for the lights too. I drove a 5 ton and HEMTT for many years and always like those switches...
Relays came from Amazon.
Luckily, the system is super simple...
You need to worry about 3 things...
Starter, Hot on Run, and Hot on Accy.
Constant 12V+ | Red | Ignition Switch Harness |
Starter | Purple | Ignition Switch Harness |
Ignition | Pink | Ignition Switch Harness |
Accessory | Orange | Ignition Switch Harness |
