Solutions to grease the steering U Joints and leaf spring bushings
Reworked LMTV
1,174
TN
I have been trying for some time to get a grease gun on those U joints in the steering. It is so tight in there, I could not get to the fitting, which was a 90 degree zerk. I ended up getting some 30 degree angle grease fitting from Fastenal. Tractor Supply did not have what I needed. I wanted 45 degrees, but Fastenal was out of them. The 45s are cheaper too. Much easier to grease those puppies now.
Anyone replace these U joints due to noise? Meritor steering U joints looked very expensive online. In the $250 range. People have said that the U joints rarely fail, if greased regularly. My observation in replacing the drive line U joints was that the bearings themselves were fine, BUT the plastic cups / seal were brittle
Fastenal:
30 degree Part number 58755
45 degree Part number 58788
Also, I saw a video of a guy working on a semi truck, demonstrating how to grease leaf spring bushings. Many on here have found, like me, they won't take grease. Some say the zerk is bad. This guy showed putting a bottle jack between the frame and the top leaf spring to take the tension off the spring to allow the grease to flow into the bushing. Pretty cool I thought.
Awesomeness
1,518
Orlando, FL
I just replaced the u-joints on my front shaft. I think they were $45 each for Neapco 4-0279 joints, and I think they were even made in the USA!
Do you happen to have a link to the video? If you watched it on YouTube recently you can go to the "History" section (I think it's on the left side).
Awesomeness
1,518
Orlando, FL
Fastenal:
Can you clarify a couple things?
The 30 degree part has a long extension on it? Was that intentional? Did you just use that temporarily to grease it, then reinstall the original short fitting? The 45 degree part number you list is a normal-length fitting.
These 1/8" NPT fittings fit? All the rest of the grease fittings on the truck are metric.
Reworked LMTV
1,174
TN
Not intentional, it just worked. Permanent. Yes, they are 1/8 NPT.
Reworked LMTV
1,174
TN
