Good source for auxiliary fuel hose & fittings?
Bmxenbrett
30
You can use JIC hyd hose. Surplus center has cheap hoses that i have used in actual hydraulic systems so i think there up to the task of this.
A parker dealer is prob going to charge you as much for one fitting as the whole hose on surplus center.
Zed254
467
S. Hampton Roads, VA
I think JIC-5 fitting is same as a 5/16 JIC: the size of the aux fuel connection on the MEP-803/802 generators. I could not find that size on surpluscenter.com.
csheath
213
FL
Leave it to the military to use a size no one else uses or stocks. :roll: My hose does have -5 AN fittings.
Daybreak
2 Star Admiral
771
Va
Howdy,
The hose blue print could be printed and taken to a hose maker. He would know exactly what is needed by looking at what is written. That is there territory. :)
