Demoh
- 26
- 18
- St Pete, FL
Talked the yardkeeper into letting me come up on a weekend to pick up the gen I bought, except he didnt tell me that he was away and his wife wouldnt be helping me disconnect the trailer from the hmmwv and onto my truck. Luckily this trailer was a whole lot more balanced than the one I picked up last month. My 140lb self was barely able to turn the trailer around by hand. I really wanted to just hop in the hmmwv but I decided against it.
So it was mfg in 2009, initially fired up in 2012. Im still confused on what they do on a level 2 reset at 2.3ish hours, but a document I found seems to shed some light on that subject. Looks like it was uncrated in 2012 with 0 hours on the set then loadbanked and various other tests, ending at 2.3 hours. This one happened to come with all of that paperwork. I dont understand why a 0 hour unit sitting for years that never had an initial test would be getting a new engine and then sent on its way. On almost all of the units rebuilt by letterkenny they are all 2.2 or 2.3 hours and some look rougher than others but they are all lister reman engines. Does the tier 2 reset involve replacing the hour meter and reseting the unit to 0 if its getting a new engine? I skimmed through the reset TM but didnt notice anything like that. I am curious on those resets.
It also came with a whole lot more. full compliment of groundrods w/ ground cable, never opened sledgehammer, slidehammer, what appears to be a slide hammer threaded stop, barrel/jerry can adapter, hoses, CD with TMs on it (nope, whoever burnt the CD dated 2012 put a bunch of shortcuts to the TMs that were on their desktop, some "amanda.p****3"... , thats like trying to use your cell phone to deposit cash....), and the tires still had all the nipples on them (2011 tires). Inside the gen is beautiful, the only rust/corrosion/missing paint is the exhaust manifold as expected and some on the belt pulleys. The engine block still has all of it's green paint. The only bad marks against this unit is sometime after 2012 when the whole unit was carc painted the panel to the fuel tank was removed. This tank wasnt nearly as bad as the 1995 I bought, I just hope it doesnt give me problems like the 1995 either.
Tomorrow it looks like I have my work cut out for me for fluids and related before initial testing even though this is the polar opposite than the 3400 hr unit I picked up that I am still working on.
Since I dont trust that the oil in the crankcase is A) the same break in oil, something doesnt 'feel' right the more auctions I watch when it comes to oil so I think it could be regular oil and not oil with high zinc / other break in additives and B) if it is oil that is 5 years old, I dont trust how broken down the detergents are and what the moisture content is.
That being said I intend on changing the oil. Does anybody know what break-in additive is recommended? I remember reading somebody posted that military started using XXX brand break in oil. I cant find it again does anybody know? Any other break-in oil suggestions? Since the coolant looks good but is unknown Im going to throw some SCA in there for good measure. (all I do is diesels, they all get worked hard and spoiled)
Have a simplex swift-e 10kw load bank that I picked up for $15 because nobody knew what it was that ive been using on generators for years. My 3400 hr 802 takes 6250 watts 30minutes+ no problem, im super curious on how this unit does.
The end goal for this unit is my primary house unit. With inverter drive air conditioner, heat pump water heater, I dont think anybody has ever used the stove, the only real load in the house is the drier. If I need more ill just sync my "beater" 802a in. Last 5 day outage we ran a 5500W screamer hacked together to run propane going through 3 cylinders a day with an old R-22 2.5ton conventional AC and kept the water heater off except when the AC wasnt running. I havent decided between installing an ATS because I have a few laying around or just keeping it manual like Ive been doing. After doing all the maths I foresee me having to split the loads up and doing what I have to do in commercial buildings and going with a critical panel and normal panel where only critical is generator. (that way my 3 phase that runs through a idler motor to generate the 3rd leg CNC mill doesnt get generator power but my webservers do. )
Ill keep the 3400 hr unit as a backup to my backup, sync them if I need more juice, and to tinker with.
