Request Pictures of Stock Engine Compartments - Various Views
dao
Southwest/Texas
The M1008 I recently purchased has been modified in various ways and I'd like to return a couple of things to stock configuration. To do that properly, I need to start with some really good stock photos for reference. Can some of you that have stock engine compartments post various views please? If you have just a minor change in your engine compartment, that would be fine too so long as you just add what is different since I understand most probably aren't using the original fuel filter. I'm not talking full restoration by any means...I just want to clean up some of the mess left by others. Many thanks in advance.
dao
Southwest/Texas
How about from the rear toward the radiator...each side. Some previous mechanic moved the coolant overflow reservoir to where the rear battery used to be located. That's one of the mods...plus a crappy 12V conversion...removal of bus bars, etc. Then, I think that'll do for now. Many thanks. By the way...really cute breather on that one...hot pink stock? LOL
Jack Lope
TX
My youtube channel has engine views that might help. I've done few different repairs. Mine all stock.
I'm Jack Lope on youtube and should be easy to find with CUCV videos.
