Kharville
- 0
- 6
- Clinton LA
Anyone know what the purpose of the sleeve that is inserted into the Deuce fuel tank is for? The only thing I see is that the fuel cap is attached to it. Other than gathering rust perhaps?
It is supposed to have a screen on the bottom of the cylinder to act a filter when refueling.
I will have to upload a pic. It has no screen and is definitely a rusty, corroded pipe. It had so much I barely got it out. Of course a bunch fell into the tank.There is a fine mesh copper alloy screen at the bottom. It does serve a few purposes.
So far, I have found nothing that came with the truck being not necessary.
I don't see that it would corrode, patina maybe, as it is copper alloy.
The neck with screen is readily available.
I have found none available, let alone any readily available.There is a fine mesh copper alloy screen at the bottom. It does serve a few purposes.
Perhaps the nomenclature on the PDF with my notes that I posted would help with the part number and the NSN. PM me and I will show you where it is.I have found none available, let alone any readily available.
To clarify, I have found no new/NOS ones available. Have found old rusty ones available.
-----I think you are right jaysonjc, many times I have done just as you said. Way less spill if you have a fuel can and no spout.If you lift it up and turn a little, it locks in the up position and makes filling from a can a lot easier. I'd bet that is the main reason for it, filling from 5 gal cans. If you ever watched any of the old WWII films most of the time they used 5 gal cans for filling.
By the way, I did not find any bats and puppies but I did find the remainder of the mesh screen and two tree branches about a foot long!it helps keep bats and puppies out of the tank, with modern pump fuel can probably pull it out if it offends you, its a little annoying when using truck pumps as it collects the foam and slows down filling, id leave it in to control slosh in case the cap seal is weak with age
