2000 mile road trip in an FMTV
TNriverjet
24
Clifton, TN
How fast do they dry out?
Sent from my SAMSUNG-SM-G930A using Tapatalk
There’s something like 12-13 oz of gear oil in the front ones. I doubt “dry out” is a factor unless there is another problem with a seal or excessive heat from bad bearings.
FYI. The rear hubs are lubricated by, and share the oil in, the entire differential and axle housing. Oil level there is also very important, but not as critical as the front hubs since the reservoir is gallons not ounces.
TNriverjet
24
Clifton, TN
Interesting. It could just be your picture, but my gauges are not nearly that bright, even on full brightness. They are barely visible, even it very dark conditions. I guess I'll have to look into that.
I’m certain you are aware of the two settings on the 3 way light switch “panel dim” and “panel bright”.
Here is the rheostat dimmer switch that also controls panel gauges.
TNriverjet
24
Clifton, TN
his light different too. Mine are back lit not digit lit. His Look sweet.
Light comes from the edges of the gauge. I did not see backlit numbers in person. I believe this appearance may be just the camera's view of things. Admittedly, I did have them on the brightest setting.
Awesomeness
1,518
Orlando, FL
I’m certain you are aware of the two settings on the 3 way light switch “panel dim” and “panel bright”. Here is the rheostat dimmer switch that also controls panel gauges.
Yep, I have mine on Panel Bright with the rheostat turned all the way up, still very dim like it's backlit with a candle. Not a big deal, but it's good to know they should be brighter. I'll take apart the panel one day... maybe the bulbs are darkened over on the inside, or something is dirty.
TNriverjet
24
Clifton, TN
Bad rheostat?
Entirely possible. I never investigated because I didn't previously realize they were supposed to be brighter.
You could try some Deoxit on the rheostat to see if it helps. I learned about this stuff in the Auxiliary Equipment section for use on the reconnection switches on a genset. It is widely regarded in the electrical community and is used extensively on old amplifiers, etc to revive these type of switches. It is available online or often in stock at your local guitar store (Guitar Center stocks it here).
You could also try Deoxit on the panel dim/panel bright switch to make sure it is making contact inside.
As with all electrical work please disconnect power prior to using contact cleaner!
Reworked LMTV
1,174
TN
Thanks guys!
I really appreciate you sourcing these for our adventure. Please make sure to let me know what resources you expelled so I can take care of it!
Thank you!
No charge. No worries : )
sjohn116
Baltimore, Maryland
Ask Longerange4u about a Roadtrip in an LmTV. He bought one and drove it 2000 mile from MD to FL and back to VA....towing a 1082 nonetheless. He survived and lived to tell the tale.
tennmogger
543
Greenback, TN
Last year, a couple of months after I got my LMTV, my wife and I headed west from TN to CO, UT, WY, MT, ND, SD and other states in between on the way back to TN. We put about 4500 miles on the M-1078 on that trip. Since then we have added another 30k miles, or what ever those units are on the odometer (ok, supposed to be miles!). The only trouble I had was some dirt in the air system but that was resolved quickly. Keep your fluids checked and carry an IR thermometer for quick checks on transmission main body, drop box, and outputs to driveshafts, and the hubs.
My advice is to take your time, don't stress the truck or you, and for sure don't try to stay on the interstates and keep up with traffic. That will wear out you and the truck. Enjoy! You will look back on this as a great adventure.
Bob
Recce01
50
San Diego, Ca
Bob
Thank you! Great advice!!
What exactly are you looking for?
yes, I am curious too!
Awesomeness
1,518
Orlando, FL
My interpretation of the lmtv and newer rigs is you need a military support system
These vehicles weren’t built to be lone rangers
Can you elaborate? I thought that a major point of the FMTV program was to use as many commercial off the shelf components as possible. To me these seem like the easiest military trucks to fix WITHOUT a military support system, unless I'm missing something.
coachgeo
3,463
North of Cincy OH
Tis way am interpreting it too.... but it is still doable. Plan your trips with strategic stops at places found thru is bulletin board to stop at and go thru the items specified by TM when you hit X # of hours or miles. Also smaller independent Big Rig repair shops would be a good place too. Some things you won't need a shop etc. Just planned full day or couple days stay to run thru the TM checks before moving on to next destination. Many wise long rangers do this in other rigs too be it a Unimog or a Isuzu.
tennmogger
543
Greenback, TN
I must not understand your question. IR thermometer measures temperature so I'm looking for heat build up. It's easier to reach potential hot spots under the truck with a laser-pointed IR gun than by hand.
Just like we check trailer bearings and dragging brakes by feeling them. A new-to-me truck deserves the same, or more, checks when starting on a long drive.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
IR thermo is great for all kinds of things including troubleshooting a miss.
I would say that with all the aforthought put into this trip, you should have no problems.
