volver
- 0
- 6
- Moline, IL.
I have been trying to hunt down and fix an irritating whining noise. Found many treads on this. None have fixed the problem.
The truck makes a whining grinding noise at 40mph or greater. First I thought it was the output shaft of the transmission. So I put all new ball bearings in the trans and replaced a wallowed out pilot bearing.
Next I rebuilt the transfer case after measuring the end play on the counter shaft and output shaft to be .018in and .010in respectively. All new bearings seals and gaskets. Set the end play to .002in then removed a .003in shim to give it a light preload.
So I have moved on to the axles. No work has been done yet.
I stumbled across this video. (1:40 noise starts)
http://www.youtube.com/watch?v=YydRamFW29o
This the same whine I am hearing. Louder at higher speed. Silent when coasting, noisy then accelerating, under load, or when decelerating. Spikes in noise when bumps are hit.
Does any one know what is causing this noise?
