CUCV Injector Pump Problems
Horsepowerparts
Germany
Hi to all.
I´m new at this Forum.
Take often a look but not registered before.
First something about me.
I´m from Germany, so sorry for my bad english :D.
I have over 15 Years a Workshop for US Trucks and Cars.
Over 10 Years I import and restore US Army CUCV Models.
Think 20 each year.
Think I have enough know-how but now we have a crazy problem.
We change gaskets on leaking Injector pumps.
Built them into the engine but they will not start.
Fuel comes to the IP but nothing goes out.
Solenoid working.
The pumps run before we change the gaskets.
This problem we have at 3 Pumps on 2 M1009.
I do not understand this.
Pump run.
Change Gaskets
Does not run.
We do not know that we have make a mistake.
All other pumps that we fixed before run good.
Does anyone have an Idea?
Thanks
Steve
cucvrus
10,132
Jonestown Pennsylvania
Gaskets on pump. I take it as you have changed the throttle shaft O rings???. If so did you get the spring back in place correctly when you removed the throttle shaft and replaced the top cover?
Mg84648
Cumming, Ga
I've experienced this same problem. With pumps that have sat unused for a period of time, it is not uncommon for the plungers to stick inside the pump. They are not damaged but the pump needs to be disassembled and the plunger freed. Your symptoms will be fuel to the pump and back through the return line and the solenoid will operate normally but little to no fuel to the injectors. Sorry for the bad news.
Hal O'Peridol
Blaine, WA
Wo wohnen Sie den in Deutschland? Ich war fuer fuenf Jahre in DDeutschland stationiert. Den ersten mahl in Augsburg, und den zwoten mal in Goeppingen. Herzliche Willcommen zum Forum!
Tinstar
1,740
Edmond, Oklahoma
I would have loved to be in Germany for 5 years.
Headed there this coming spring.
Hal O'Peridol
Blaine, WA
It was great. I went to DLI (Defense Language Institute) to learn German as a Voice Intercept Operator and then was stationed there twice. Good beer, good looking women and good times! Put many miles on CUCVs, Dueces and Tracks driving throughout Germany.
